How much boost?
Old Apr 18, 2004 | 10:02 PM
keithq's Avatar
Default How much boost?
I have a 1969 Camaro with a 99 LS1 and T56 in it.
I am just finishing the car for this summer and am going to run the engine stock for this season.
I am collecting parts for a twin turbo kit. I am going to run 6.0L heads and a stock short block for next year.
My fuel system should be up to task, I am going to feen each fuel rail in through the front with a 6AN line then off the back into a boost referenced regulator. I am running one intank pump for now but will add an inline pump when the turbos go on.
How much boost can I run with this setup?
What boost level will dictate a change in injectors?
Keith Quinn
Old Apr 19, 2004 | 03:01 PM
keithq's Avatar
Nothing??
Old Apr 19, 2004 | 04:55 PM
scottywheels's Avatar
you dont give enough info, what type pf pump? stock fuel rails ex. you will need edit and different injectors...
Old Apr 19, 2004 | 05:24 PM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
We need a little more info.
Old Apr 19, 2004 | 10:59 PM
keithq's Avatar
Okay, let me see if I can give you guys the info you are looking for.
First of all the fuel rails, I am modifying the stock fuel rail by removing the ends of each and replacing them with a weld-on 6AN fitting.
The fuel line will feed in through the front of each rail and then out the back and into the regulator. The pump in the tank now is a stock 99 Camaro pump, I will add an inline fuel pump when I add the turbos.
The turbos that I am considering are Garret T04B's, they have a 54mm compressor wheel with a .60 AR and a P trim turbine with a .96 AR. I think the turbine housing is too large for optimum spool time but I can get a good deal on these. I think I can change the turbine housing if it is a problem.
I will build my own stainelss 1.75" headers and get them as close to equal length as possible. I am going to use two large intercoolers, one for each turbo.
The cylinder heads will be stock 6.0l heads, I think that gives me about 9.1:1 CR.
I live close to Agostino Racing so they will be doing a dyno tune for me.
Let me know if I have left anything out that you need.
Keith Quinn
Old Apr 20, 2004 | 10:00 PM
stock rails run out about 600 rwhp also you are going to need a fuel system like prostock and I run with external pump and -8 or -10 feed with billet fuel rails for the power you want to make.
