T70 vs T76??
Old Feb 20, 2013 | 10:52 AM
1bad03snake's Avatar
Default T70 vs T76??
I have a magnum T70 on my 6.0L. I was going with a gt45 but it was to big and I couldn't get the hood to close. I researched and found that a magnum t76 is the same size so I could upgrade. Would it be worth it to upgrade? I am limited to 7" total height from the foot of the t4 flange to the top of the compressor housing. Anything bigger and I'll have to mad max the hood
Any info is appreciated
Old Feb 20, 2013 | 10:59 AM
67Firebird455's Avatar
Depends on if the magnum 76 is running the same turbine as the 70. Do you have any more info? Stock 6.0, boost level?
Old Feb 20, 2013 | 11:25 AM
Stock rebuilt 6.0 with arp bolts, tu1 cam, 317 heads. Id like to run 10-12lbs. 15lbs once in: a while. lll find out about the turbine
Old Feb 20, 2013 | 12:20 PM
Ferocity02's Avatar
With a 6.0L the Magnum turbine seems awfully small. I think they come in 65 and 68mm. Perhaps look at the new Turbonetics 76/75. I believe it has the same physical dimensions as a Magnum T70 so it should bolt right in. Huron Speed can get you a good deal on them. Ask them for some dimensions as well.
Old Feb 20, 2013 | 12:45 PM
I think you're right too. Those units would be good on a 4.8. Even a 68mm turbine is too small for a 364. The 7675 is an excellent turbo and a lot of guys making huge power with them. I opted for a 96mm turbine BW S475 for my 6.0 because I refuse to have 4:1 BP from a tiny *** turbine.
Old Feb 20, 2013 | 01:12 PM
I'll check them out
Old Feb 20, 2013 | 05:04 PM
T76s10's Avatar
Time to start cuttin **** up to make space! Throw a s475 in there
Old Feb 21, 2013 | 05:38 AM
LS1NOVA's Avatar
7675!!
Old Feb 21, 2013 | 03:27 PM
The 7675 will fit. Its the same size. Now to come up with.1200.00
