oil feed question
Old Feb 25, 2013 | 02:03 PM
LsXRs's Avatar
Default oil feed question
I have a question i bought a member car off here and was running a turbo only his turbo blew so he sold it and now its my project.
My question is where is a good oil feed for a turbo?
ive seen my engine has a an fitting down in the oil pan and another in the front engine cover.
Which one would be the best for feed?
i looked in the sticky and it said that the oil pan is good for a return so i was wondering if that is what i should do.
thanks
Old Feb 25, 2013 | 05:39 PM
GMouldy's Avatar
my oil feel is ran from the oil filter housing.
Old Feb 25, 2013 | 05:44 PM
GMouldy's Avatar
https://ls1tech.com/forums/forced-in...ion-block.html
Old Feb 25, 2013 | 06:55 PM
supersick99z's Avatar
Feed from the block off above the oil filter and drain to the oil pan or the timing cover
Old Feb 26, 2013 | 12:41 AM
LsXRs's Avatar
Oh ok so the an fittings my engine has are both return and none of them a feed correct? i Have a an fitting on my front engine cover and the oil pan i will post pics tommorow of them.
