Low Compression + Pump Gas... How Much Boost?
Let's try it on yours!
If you have any more negative comments rather than constructive please see your way out if this thread. Thanks for your previous input.
You could run low boost with more timing or run higher boost with safe timing. It's all relative really.
Let's say car A is running 600WHp @ 12psi and 15 degrees advanced, while car B is running 600WHp @ 16 psi but with 12 degrees advance. Both are same combos making the same power and are properly tuned with no detonation. One car may be more efficient in the compressor map, one may spool faster, etc.
That being said you dont know how it will react to added timing until you tune it as well. If you feel its safer with a lower psi and is making the Hp or desired performance, leave it.
I would think the pt88 would love more psi to get into it's efficiency range, so I would try to shoot higher psi while it gets tuned and then run it at lower boost settings 90% of the time, so when you do want to up it a bit, you can without getting it re-tuned.
So shoot for 15-17psi. If you feel running at 14 psi is all you need, then back it down and let it live a long life. Once you get used to the power level, you will want to turn it up more, its not a fact of if, but when.
JMO
On a low compression motor you will start to see a lot bigger gains by adding boost rather then timing.
JMO
I would like to do exactly what you said and run around 90% of the time on 13-14 psi, but not have to get it re-tuned (yet again) just to run a little more boost only 10% of the time if it can be dealt with the first time around. In fact, it is more likely that I would keep it in the 14 lb range closer to 95% of the time. lol
Anyways... I do know better than to just turn it up and have good faith that everything will go smoothly.
