Necking down a down pipe
Old Mar 21, 2013 | 07:14 PM
  #101
Hank Peabody's Avatar
Originally Posted by Martin@Tick
It was a joke.
It was a joke here too?
Run the biggest down pipe you can fit. I'd make it as large as possible, I'm running a single 5" downpipe split to dual 4" exits. Size matters.
Old Mar 21, 2013 | 07:16 PM
  #102
Originally Posted by LilJohn
Too much dick swinging...... PERIOD.
Pot meet kettle.
Old Mar 21, 2013 | 07:21 PM
  #103
Sarg's Avatar
Originally Posted by Hank Peabody
For a stock pistoned 5.3 it is overkill. We're not talking about anyones max effort forged pistoned engine, this thread was about a stock pistoned 5.3.
Haha, I am doing a S480 on a stock piston 5.3 Not sure what will happen, but I wanted to try to push the stock pistons a bit!
Old Mar 21, 2013 | 07:26 PM
  #104
LilJohn's Avatar
Pot meet kettle.
Nice edit job. Way to make it look completely different from the way it was originally presented.
Old Mar 21, 2013 | 07:28 PM
  #105
69-chvl's Avatar
Ideally for your situation i would run 4 inch as far as you can, do a nice smooth conical reducer to 3.5 and fit that how you need to fit it. This method allows you to maintain as much pressure delta as possible so the wheel stays efficient. As you go back the exhaust will cool causing density to increase and airspeed to drop. The conical reducer will help accelerate the gas and hopefully prevent excessive post turbine pressure.
Already ordered the parts to do exactly this.
I will likely dump the exhaust before the rear axle for now, using 2 straight-through 3" muffs
Old Mar 21, 2013 | 07:35 PM
  #106
LilJohn's Avatar
Should work well for you.
The 87mm wheeled 400 is a nice matchup for what you are asking out of it.
Old Mar 21, 2013 | 08:20 PM
  #107
Thank you, anyone is free to go back and read your chest thumping in its entirety a few posts up.
Old Mar 21, 2013 | 08:21 PM
  #108
Its 83mm.
Old Mar 22, 2013 | 09:42 AM
  #109
MIGHTYMOUSE's Avatar
Too much dick swinging i did blah blah 150 years ago bullshit. Theres a right way and a wrong way. The right way is whichever way makes the turbo the MOST efficient. PERIOD.
Look out swinging back this way lol!
150 years ago and your sig reminds me of when i made 800 to the tires with 346ci and stock 98 f body camshaft. (same downpipe since then)
been doing it wrong and kicking *** since 2003!
the real right way is to do what makes you happy.
what makes me happy is beating people with t6 turbo's, aluminum intakes, and 4" pipes.
Old Mar 22, 2013 | 10:28 AM
  #110
Sales@Tick's Avatar
You got me!
Old Mar 22, 2013 | 02:10 PM
  #111
69-chvl's Avatar
Sig material right here!!!
Old Apr 19, 2013 | 09:20 AM
  #112
69-chvl's Avatar
Bringing this back up guys.
Since I'm utilizing the divided housing and 2 w/g's, do you think its OK to "T" the 2 w/g discharge outlets and then into the 3.5" DP, or should I keep them out of the DP as this DP may sorta be on the small side to begin with? I was thinking of just venting the w/g's to the atmosphere with a small bullet muff on each end, but that will add more weight and complexity. Being that the car is driven in a populated area I dont want it unnecessarily loud.
Am I splitting hairs here - just run them into the DP???
Old Apr 19, 2013 | 09:42 AM
  #113
T/ALT1's Avatar
Just run them into the downpipe, you are just splitting hairs at that point.
Old Apr 19, 2013 | 09:53 AM
  #114
Sarg's Avatar
Just remember the only time you will hear ones that are dumped to atmosphere is when you are at or close to full boost.
Old Apr 19, 2013 | 12:30 PM
  #115
69-chvl's Avatar
Ive never heard an open w/g, and can only imagine its pretty loud
Old Apr 19, 2013 | 01:03 PM
  #116
Sarg's Avatar
Let's people know you are coming loud pipes save lives!
Old Apr 19, 2013 | 01:38 PM
  #117
leave to atmosphere. they are closed during normal driving
Old Apr 20, 2013 | 08:20 AM
  #118
95bowtie's Avatar
Pretty good example right here what it sounds like. It's nicd's car I think that's his name on here but anyway looks to be from 07 lol.
Sounds pretty quiet overall but when he gets into boost it really screams. I personally love a wg dumped to atmosphere.
Video:
Old Apr 20, 2013 | 10:13 AM
  #119
69-chvl's Avatar
Video: https://www.youtube.com/watch?v=2Ce0...e_gdata_player
Thanks for posting. I'm not sure what I'm listening for, but I assume its the higher-pitched scream when he's on the throttle? Doesnt sound too loud in the car but I can only assume its pretty loud outside???
Old Apr 20, 2013 | 02:59 PM
  #120
jridenour31's Avatar
It just sounds like a naturally aspirated car out of the dump. Dump to atmosphere, you only hear it when the wastegates open and it won't make your already too small downpipe worse. You don't need mufflers on the dumps, either. If you're somewhere and don't want to be loud, don't go wot, it's not a problem.
