L33 stock cam and boost
Old Mar 12, 2013 | 11:51 AM
ronnieforrester's Avatar
Originally Posted by 71 chevy
stock truck cam in a 6.0 at 11 psi, back when it weighed 3000lbs.
the same cam will act bigger in a 5.3
just letting you know what the free cam is capable of
http://www.youtube.com/watch?v=rkuFH6Yd59g
very nice !!!
Old Mar 12, 2013 | 02:24 PM
LS1NOVA's Avatar
Originally Posted by ronnieforrester
what was the final dyno number ?
824 flywheel on 16psi.
Old Mar 20, 2013 | 06:26 AM
skinnies's Avatar
Originally Posted by skinnies
After tx2k13, we'll strap down a 5.3 / 76mm setup in maxxmitchell's car and see what it does with the stock l33 cam.
No dyno on it, but the 3rd gen did go 9.44 at 144 at 25-26lbs. It's definitely down some power vs with a small cam, but at his weight I'd guess that to be in the 750-800rwhp range. It did go 142 on 21lbs, so above 20lbs or so it isn't gaining a lot per lb of boost which didn't really suprise us much.
Old Mar 20, 2013 | 01:15 PM
MaxxMitchell's Avatar
Here is the slip for those wanting more increments. It definitely felt like it was out of power above 5300, and that was over half the pass in 3rd. The car weights around 3600lb at raceweight. I will be swapping the cam before I get it on the dyno, but for those of you wanting to save some money you can definitely make good numbers and run quick at the track on the stock cam.
Old Mar 20, 2013 | 01:53 PM
69-chvl's Avatar
That is unbelieveable Maxx
How much boost did it take to do that?
Stock valve springs?
Old Mar 20, 2013 | 11:22 PM
I ended picking up a CheaTR cam local for a great price. I still want a custom turbo cam but I think the CheaTR cam has to pull harder up top than a stock cam.
214/230 .601/.575 117 LSA
Old Mar 21, 2013 | 08:32 AM
26lbs
Old Mar 21, 2013 | 12:11 PM
T/ALT1's Avatar
The L33 that I bought has the single bolt cam and I plan on getting the car running with that cam with the turbo then swapping it once evrything is in order. Can you just swap in a 3 bolt cam in these Gen 4 engines?
