Fbody coolant overflow reservoir relocation question
Old Mar 19, 2013 | 08:11 PM
evo462's Avatar
Default Fbody coolant overflow reservoir relocation question
My turbo plumbing runs right where the coolant overflow reservoir once was, and I completely forgot that I needed to figure out what to do about that until tonight. Just looking for input on what container to use and where you placed it on your Fbody. Tried searching and couldn't find much.
Thanks!
Old Mar 20, 2013 | 11:25 PM
evo462's Avatar
no input?
Old Mar 21, 2013 | 05:04 AM
Camaro9969's Avatar
Buy or make a new overflow tank you can mount it anywhere you want some guys even put them in the back of the car
Old Mar 21, 2013 | 07:39 AM
Sweet_SS's Avatar
I've used something similar to this in my old car.
http://www.autozone.com/autozone/acc...mString=search
or
http://www.oreillyauto.com/site/c/se...coolant+bottle
Old Mar 21, 2013 | 08:21 AM
pnykillerz28ls1's Avatar
i stole one off of a marine engine cause i work on boats it looks exactly like the second one in the first link sweet ss posted
Old Mar 21, 2013 | 09:53 AM
oange ss's Avatar
i used one like in the second link when I was NA, I built my own out of some extra 3" aluminum tubing I had laying around because it has to go on the opposite side of the rad now that the turbo is in.
Old Mar 21, 2013 | 06:50 PM
ACCLR8N's Avatar
The only design requirement is that the end of the overflow hose remains submerged so that it pulls coolant back in when it cools off. It can be higher or lower than the radiator cap, it doesn't matter. It doesn't need to be sealed. When I first started up my turbo project, my overflow was the hose dropped in a half gallon milk jug sitting in front of the A/C condenser. I recommend something that holds close to two quarts or better. One quart you will have to keep a close eye on it.
I made little bit better one out of left over tubing as well with a brass hose barb screwed in near/at the bottom. I salvaged the top vent and cap from the cars original.
Old Mar 21, 2013 | 10:04 PM
evo462's Avatar
Thanks for the info. Now I just need to figure out where to place it...it's a bit tight up front with the intercooler, transmission cooler, stock fans, etc.
Old Mar 22, 2013 | 08:56 AM
MIGHTYMOUSE's Avatar
mine was one of those auto zone deals, the larger one that came with a bracket. it as mounted to the fender liner on same side still gave enough room for 4x12 air filter in front of it.
found a pic!
Old Mar 22, 2013 | 06:45 PM
jjcamaro02's Avatar
Here is one that i am buying.
http://www.summitracing.com/parts/rnb-603-001
Old Mar 22, 2013 | 07:26 PM
forgedlt4's Avatar
I use this
its a fill/overflow combo tank. custom made
Old Mar 13, 2015 | 01:34 AM
nasty_ss's Avatar
Does is matter if it's recirculating?
Old Mar 13, 2015 | 06:24 AM
ACCLR8N's Avatar
Yes. Your overflow hose has to enter the bottom or extend from the top so the end is always emersed. If not the system will suck air instead coolant back in when it cools off.
Old Mar 13, 2015 | 09:07 AM
sssalah's Avatar
Using this integrated CBR ice tank and coolant overflow tank.
Old Mar 16, 2015 | 01:57 PM
VTC_WS6's Avatar
http://www.andysautosport.com/produc...6-111-101.html
Holding up well for me thus far.
