Are my pcv breathers and vacuum/boost line correct?
Old Mar 22, 2013 | 08:07 PM
sweet99ss's Avatar
Default Are my pcv breathers and vacuum/boost line correct?
The red circles are where I want to put breathers for the pcv setup.. Is that right? I already have a breather on the pcv hose that went from the back of the valve cover to the passenger side of the intake manifold. I used this spot that was for the pcv for my vacuum/boost lines. I lined it in blue so you can see where it goes. It comes right off the pcv nipple on the intake and goes off into a T for the boost gauge and the bypass valve. I started the car and have no leaks and the gauge shows good vacuum and the bypass valve opens up. So it looks like the vacuum/boost are good to go, but my main concern is if the pcv will be right with breathers on all those spots?
Old Mar 22, 2013 | 09:36 PM
sweet99ss's Avatar
Anybody
