how much power will a 4.8 make.
Old Mar 28, 2013 | 07:36 AM
mustang93's Avatar
Default how much power will a 4.8 make.
Im building a race car 96 mustang with turbo LS swap. It is an all out drag car but 6 liters are getying hard to come by and the ones that are out there everyone wanys Top Top dollar. i have found a few 4.8s. And i also found a 6.0 priced ok but its 4 hrs one way away.guess my question is will i be able to make big power out of a big single turbo 4.8. Or should i not even waste my time. ?
Old Mar 28, 2013 | 07:39 AM
Blackpanther99's Avatar
What are your HP goals?
Cuz 4.8s can hold real good power. Foose(member in this forum) was pushing over 900+RWHP on a stock bottom end.
Old Mar 28, 2013 | 08:17 AM
mustang93's Avatar
As much as i can. Looking to run mid 8s in the 1/4.
Old Mar 28, 2013 | 08:48 AM
a4ls2goat's Avatar
they can all hold the same power.
what ever motor you decide to get make sure it has the ls2 style rods in it.
Old Mar 28, 2013 | 08:57 AM
BMF_Racing's Avatar
Thumbs up
x2 Very true, they are the stronger floating rods. In truck motors they started in 2003 with the ls2 style rods (also 58 wheel on the crank).
IMHO, you will be on the edge of the rods limits to run mid 8's. It can be done, but for how long is a question. Forged rods and pistons and it will last at that level with a good tune. Just my $0.02.
Good Luck.
Old Mar 28, 2013 | 09:11 AM
mustang93's Avatar
Would the 6.0 make A LOT more power over the 4.8 with the same parts?
Old Mar 28, 2013 | 09:17 AM
a4ls2goat's Avatar
A little research will answer your questions.
Old Mar 28, 2013 | 09:26 AM
mustang93's Avatar
I have been doing research and that is why I am starting this thread.
Old Mar 28, 2013 | 09:46 AM
It all depends the parts and the fuel you use as well as your fuel system. I would be more safe with a 04 or newer LQ4.
Old Mar 28, 2013 | 10:54 AM
mustang93's Avatar
Thanks. Im just going to do it right the first time. Im going to pick up the 6.0.
Old Mar 28, 2013 | 11:16 AM
BMF_Racing's Avatar
they all will bend the rods at about the same whp the only different is you run alittle more boost with the smaller engines. So it really doesn't matter, 800whp in a 4.8 @ 20+ psi and bend the rods or do the same with a 6.0L ... 800whp at alittle less boost and bend the rods.
Old Mar 28, 2013 | 11:45 AM
1fast bird's Avatar
Whatever is cheapest IMHO. You can't ask a stock longblock to hold up too long if running max effort. Doesn't matter which one you use, it won't let you run mid 8's long, unless your car is 2400 lbs..... The 4.8 will get you as much power with boost as the 6.0, it just may take a few more pounds to do it.
If your goal is to run mid 8's you better pay the extra money now to get a forged short block. The 6.0 will be easier to find forged pistons for if that helps.
What does the car weigh?
Old Mar 28, 2013 | 12:10 PM
Daniel0026's Avatar
also this
http://www.hotrod.com/techarticles/h...g_bang_theory/
(this is a 4.8)
Old Mar 28, 2013 | 01:26 PM
mustang93's Avatar
Originally Posted by Daniel0026
I already read that article but thanks
Old Mar 28, 2013 | 01:55 PM
JAX04's Avatar
1200+! havent you read the hotrod article! lmao
Old Mar 28, 2013 | 03:54 PM
HRHohio's Avatar
Don't waste your time... those $500 4.8s let go at around 919 rwhp. <Sarcasm... for those who can't tell>
https://ls1tech.com/forums/forced-in...80tq-4-8l.html
(2005 4.8L Twin Turbo going into my 72 Camaro as we speak).
Old Mar 28, 2013 | 04:09 PM
HexenLord's Avatar
I fail to see how thats right.
Naturally aspirated you should go with bigger cubes. Forced induction on a stock motor you should go with whichever is cheaper. Given they have the same rods they will hold roughly the same amount of power before breaking. The 4.8 will run to a much higher RPM which will be better for drag racing if you're trying to squeeze the best ET out of it. It also has the shortest stroke which means less leverage on the rods from the crank and less side load on the pistons.
Things like this would technically make the 4.8 the strongest stock shortblock for boost.
You're doing it wrong.
Old Mar 28, 2013 | 04:38 PM
MonmouthCtyLS7's Avatar
screw the 4.8, pick up s LY5 off of Ebay for 175 bucks plus shipping....
