B4c turbo build!
Old Mar 31, 2013 | 09:05 AM
t57b18's Avatar
Default B4c turbo build!
I'm in the process of gathering parts for my first turbo lsx build .my first purchase was a 99 b4c chassis with a few mods but no motor or trans , the plans for this build is 10.99 or faster and to learn a different chassis and motor (came from the Honda world) if you have any suggestions please fill free to speak.i will get some pics posted when parts start showing up . Here is chassis set up and what I have planned to use on the build .
Chassis mods
99 camaro
Moser 9in spool with 370 gear
Wilwood rear brakes
Bmr control arms,tq arm,subframe connectors,trans cross member
Umi k member
Motor
5.3
Ls1 intake/tb
Ls6 cam and valve springs
New oil pump
New push rods
eBay head studs
New head gaskets (still undersided on what to use)
Trans
Th 400 rebuilt
Stall (still need to figure out what I need)
Turbo kit
Truck manifold with vbands
2.5 cross over pipe
Turbo ether pte7675 or eBay gt45 ( I have a Borg s372 but I think it's to small)
Tial 50mm bov
Hks style 60mm waste gate
31x12x3 intercooler
2.5 hot side piping
3 inch cold side piping
Fuel
Billet fuel rails
Aeromotive fpr
-8 feed
stock feed as return
Billet fuel filter
80# injectors
255 intank and 044 inline pumps
Cooling
Scirocco Pro stock jegs radiator (hope it works well it will free up lots of room )
2 12inch pusher fans
Billet over flow can
Old Mar 31, 2013 | 10:58 AM
Ryan K's Avatar
Pathological Modifier
Good luck, it's cool to see more B4Cs like mine running around.
Old Mar 31, 2013 | 12:34 PM
01transampower's Avatar
The 3.70 gears maybe a little to tall for a turbo build plus with an auto you'll run out of gear up top.
Old Mar 31, 2013 | 08:32 PM
t57b18's Avatar
That's what the car had when I bought it I'm looking in to a 3.42 gear at the moment .
