Utilizing a divided housing
Old Apr 8, 2013 | 05:50 AM
Sarg's Avatar
To keep it in a twin scroll and keep the exhaust pulses seperated, you gotta pretty much use 2 wastegates and keep them on their respective banks of cylinders. That is what I did on mine with twin 38mm wastegates. But you can use a single with the divider going all the way to the wastegate flange with a little lost efficiency. Of course either will work, but if you are going to the trouble to do a twin scroll set up I would use it to its full advantage and use 2 wastegates, one per bank of cylinders.
Old Apr 8, 2013 | 07:02 AM
69-chvl's Avatar
Yeah I keep fogetting about that part. Thing is, it will become just as much an ordeal to run the w/g piping as the hot sides. My downpipe at 3.5" is already on the small side and I dont think running 2 more 1.75" pipes into it is helping the cause. I may just run a small bullet muff off of each w/g to keep the noise down and plumbing a little simpler
Old Apr 8, 2013 | 07:47 AM
Sarg's Avatar
Ah just dump em. You will only hear them at WOT anyways.
Old Apr 8, 2013 | 09:22 AM
69-chvl's Avatar
I thought about it but seems most folks who do that end up plumbing them back into the d-pipe after a while.
Old Apr 8, 2013 | 09:27 AM
Camaro9969's Avatar
What you plan on running for a dp? Or you running full exhaust
Old Apr 8, 2013 | 09:55 AM
Sarg's Avatar
porche actually ran little mufflers on the wastegates of one of their cars. I just plan to dump mine as the single 4" out the fender will more than likely drown out anything the wastegates could do, lol.
Old Apr 29, 2013 | 09:20 PM
69-chvl's Avatar
Any issues or concerns with making sure the 2 wastegates are metering properly together? Was wondering what happens if one gate is more sensitive than the other. Do you link them togther via vacuum hoses?
Old Apr 29, 2013 | 10:54 PM
ayousef's Avatar
another stupid way around this would be to measure pressure in each exhaust manifold and account for it by fine tweaking the individual wastegates so both sides have the same pressure.
Old Apr 29, 2013 | 11:33 PM
Driftin_240sx's Avatar
Twin divided s256 manifolds for a c6. Spools hella quick. Would I do it again. HELL NO! Not in that car.
Old Apr 30, 2013 | 07:10 AM
69-chvl's Avatar
Wow..impressive to say the least!!
Just when I thought my welding skills were getting a little better I see this...
Old Apr 30, 2013 | 07:12 AM
69-chvl's Avatar
Wouldnt the exhaust pulses somewhat equalize once they hit the turbine housing right??
Old Apr 30, 2013 | 08:27 AM
  #32
Sarg's Avatar
Heck yeah! I am really curious to see results from the twin s256 turbos. I have been waiting for someone to try those, but was thinking it would be on a 4.8 or 5.3 motor. I love those little turbos on single 4 banger applications. Is there a build thread on it anywhere?
To answer the above question, the pulses do not merge til after the turbine wheel really.
Old Apr 30, 2013 | 08:55 AM
  #33
They spool really fast on the street. The car made 550 @ 5psi so far. I am doing a cam, headgaskets and studs right now and turning up the wick. All I can say is for a street application the s256 works wonders..
It is my personal car that a friend and I built in my garage. Never started a build thread but here is a link that has a bunch of pictures of the progress..
Twin Turbo Corvette Build
Old Apr 30, 2013 | 09:50 AM
  #34
Sarg's Avatar
I hit right at 400/400 to the wheels on 2 different 2.5 liter motors with 20psi and almost no timing combined with fat air fuels (both stock long block motors). Spool was very quick and both are still on the road today 7 years later. One now has 215,000 miles! I think you will be very happy with them, although on a larger motor they may die off a tad up top.
Old Apr 30, 2013 | 10:07 AM
  #35
69-chvl's Avatar
I just looked at the bare housing, and each housing meets directly at the center of the turbine, so I guess a slight difference in pressure wont make too much a big deal as the'll equalize - at least in my mind!
Old Apr 30, 2013 | 10:50 AM
  #36
jridenour31's Avatar
Lol you're thinking too hard now.
Old Apr 30, 2013 | 01:51 PM
  #37
69-chvl's Avatar
Maybe...but that's just how I roll
Old Apr 30, 2013 | 03:11 PM
  #38
I'm the same way lol. Think about a set of twins, the banks never come together, whatever slight pressure difference there is doesn't matter.
