S480 guys....fuel system ?'s for ya
Old Apr 5, 2013 | 01:22 PM
streetknight2's Avatar
Default S480 guys....fuel system ?'s for ya
What size injectors are you running?
What Kind of fuel?
Size fuel lines feed and return?
What fuel pump you using?
What engine management? Stock ecu, Megasquirt, etc.
Thanks guys.
Old Apr 5, 2013 | 02:06 PM
meatheadgn's Avatar
I have a BW S488 turbo but it should be close enough.
I have Bosch 1000 CC injectors
91 octane unlead as I am at 4500 ft elevation
-10 feed -8 return line
Magnafuel 4303 pump
Holley EFI HP for managment system
This is a 408 in a Vega so I did not need any trans control or any emissions equipment.
Just getting ready to start the engine in a few weeks.
Old Apr 5, 2013 | 03:20 PM
Camaro9969's Avatar
Siemens 80lb injectors but 58 psi base fp
Pump gas till I switch to e85
-8 feed -6 return
Twin 255s
Stock ecu with HP tuners
Old Apr 8, 2013 | 10:09 AM
Sarg's Avatar
I am running:
e85 with an Aeromotive Eliminator
Aeromotive fuel pump controller
bosch 160s
-10 feed and return.
It idles well at 850 rpms on pump or e85.
Old Apr 9, 2013 | 12:42 PM
Compressor Surge's Avatar
-10 feed
split to dual -8 before the rail
-6 return thru a flex fuel sensor
Fuelab pump
Fast Rails
Siemens 80 lb injectors
Megasquirt MS3x controlling the pump via PWM
Not running yet, but will be within a couple weeks
Old Apr 9, 2013 | 01:41 PM
Twin turbo c5's Avatar
I have a intank a1000 with -6 feed line , -8 return and 80lbs injectors, stock fuel rails. 670 rwhp 623 tq
Old Apr 9, 2013 | 02:55 PM
Trl_ws6's Avatar
Holley 120lb injectors
E85
-10 feed/return
Magnafuel 4303
Holley Dominator
