Help on my V2 vortech
Old Apr 6, 2013 | 07:39 AM
Behold81's Avatar
Default Help on my V2 vortech
Ok guys. I'm wanting to know if I'm getting this all wrong or maybe not and its all I'm getting.
I have a VT commodore with an LS1. The engine is on stock cam and heads. I fitted a V2 charger a while back running of the PAS pump and this caused issues with belt slip on the aux belt. So the last year with some help I have converted this to crank driven. As far as the crank drive goes it works and no jumping on the belt is a good sign.
The issue is I'm not making a lot of boost. If my latest calculations are right I am spinning my V2 at about 51k and all I manage is 4psi of boost.
Earlier I had a larger pulley on and it was running 3.5psi and about 46k spinning.
So what's the issue? my BOV not working?
The boost is not really linear it's a light rise. On my old PAS setup I made 5psi of boost not IC'd and my calculations put the blower at 51k
It seems like the boost is too low for this sort of RPM. Am I mad? should I replace my BOV( its a Bosch unit)
Could I have a leak else where??? Any help appreciated.
Thanks
Old Apr 7, 2013 | 03:45 AM
Behold81's Avatar
New info.
Did a run and mapped this against RPM with the BOV blocked off. I'm still getting to about 3.5k theit tails off. Where could my leak be? it's not tha I can identify the pipework from the charger to the IC but not 100% cleared. Could the SC unit be at fault? Or the ls1 intake? antway to test the intake.??
Thanks
Old May 9, 2016 | 11:06 PM
Boostedd's Avatar
Hi
I'm having the same problem but obly getting 2 psi at 3500 rpm
Than just dropps off to 0 to 5500 rpm
Did you find out what your problem was ??
Old May 10, 2016 | 09:21 AM
forcd ind's Avatar
I have had pipe conns. pull out under boost, then go back together off boost-I went to the t bolt clamps, made sure there was a ridge on the pipes, cured that problem-def had me scratching my head, lol
Could also be belt slip
Old May 12, 2016 | 05:11 PM
stevieturbo's Avatar
Originally Posted by Boostedd
Hi
You have a boost pipe off, or the belt is wayyyy too loose.
