Another Fbody PROCHARGER Build***
Well, it was straight as an arrow...
Methanol system is not installed yet but will be by next weekend.
So, should I install the methanol kit and dyno it and just leave like that for a while, or go ahead and up it to 10 lbs and call it a day?
ATI ProCharger and Moser Sales 260 672-2076
PM's disabled, please e-mail me
E-mail: brutespeed@gmail.comob@brutespeed.com
https://brutespeed.com/ Link to website
I guess that's either a vacuum leak or bad red race bypass? These bpv's aren't supposed to be adjusted, I've been told.
Ha. Can I borrow some money then? J/k, but I'm a little hesitant about losing pieces of my front bumper and having methanol premix in the washer tank at the same time.
So I got the plenum welded at a boat prop shop for $30, and cranked down on the outlet side hose clamp. Bypass is acting normal again.
But peak boost according to the gauge is only ~7 lbs with the smaller pulley. Feels stronger though. Need to log it with HPtuners and see what the MAP says... Hard to watch a boost gauge at 6k rpms. I smoke tested it at 5 inHg after the repairs and smoke only came out of the air filter.
Either I have a leaking gauge, leak otherwise, or need a smaller pulley.
What is the best way to block off the air filter for a smoke test?
im not sure what you mean by blocking off the air filter. most people put a tester on the intake side of the blower where the inlet hat would go and go from there. maybe im just not understanding. i am drinking octoberfest by the gallon as we speak.
My smoke tester has a little cone shaped nozzle that I stick in the Evap solenoid hose that goes into the drivers side of the intake manifold. What kind of piece/setup fits on the blower inlet like you're talking about?
Thinking of holding off on the methanol until spring, but I'm not sure yet. I may pulley down if my next boost leak test doesn't reveal anything. If I do pulley down then the methanol will go on. Or I may just up the boost till it blows and then tell the wife "I dunno what happened... Just gonna have to buy a new motor I guess!"
I plan to do both but does it really matter which is done first? Would the D1SC be choked down by my 3.5" IC setup if I upgrade the blower first?
I would install my methanol kit with either upgrade.
I should probably state that after upgrading the head unit and IC set up I then plan to upgrade the motor to a 383 with trick flow 225 heads with 67 cc chambers (to retain the factory compression ratio), and I will upgrade the cam as well to match the cubes. Not looking to make a drag car, just an awesome street car that still has midrange power.
I would probably just run yours the way it is for a while. Did you dyno it? Selling and buying another kit is going to another ton of $$.
