Turbowerx pump issue
On initial testing of the pump's wiring, it powers on correctly, but sounds like it's pulsing instead of a whine that'd I expect. Having no experience with the Turbowerx pump, I assumed it was supposed to sound like this, and continued with start up. All seemed well for about 3-5 min and the car started smoking pretty bad from the oil back up in the lines. We could hear the pump running, but something's not right. Keep in mind all of this was at an idle, no high rpms involved.
I'm hoping someone who's used this pump will chime in with some tidbit I'm overlooking. Marc from Turbowerx is telling me it's an over oiling issue, and to add a restrictor. I'm just not sure this is the issue. I'm going to get a vid up later on of the pump running. It just doesnt sound right. Thanks in advance for any help.
I used one of their basemodel units on my rearmount setup and ran a restrictor.
But adding my 2 sense, ive been apart of maybe only 15 turbo builds and none of which we ever used a restrictor in any of the turbos.
The only time i ever had an issue was with a poor drain. On the 4 kits, 3 rear and 1 low front mount, ive used the turbowerx EXA, and the shurflo pumps and never had a smoking issue either.
Seems odd that some folks have the most trouble and some have never had an issue.
Interesting.
OP, what does the setup look like? Do you have a 90* coming right out of the turbo into the pump?
