Adjusting sdce tensioner ???
Old Apr 30, 2013 | 06:19 AM
ramairetransam's Avatar
Got it all down two days ago . My brother came over and it totally takes two people to do it . I was underneath holding the tool on and a 3/4 socket. I don't see how we would have done it another way with prying but its on and done . I just hope i don't have to do that again . The tool needs a major rework . The idea is there it just doesn't work correctly . Got the thing locked on at 15 and everything is good to go .
Old Apr 30, 2013 | 06:20 AM
also before i forget ,mine doesnt have the dust plug . Anyone know where i can get one , or what the tensioner is off of so i can go buy one and grab the plug.
Old Apr 30, 2013 | 07:10 AM
RONSBLACK1998TA's Avatar
I never had the tensioner tool because I bought my entire system used and the guy didn't send it. I have the same SDCE tensioner also. I removed the stop bracket on top of the tensioner. CAREFULLY place a pry bar on the pulley itself, then tighten the 3/4 nut holding the tensioner. Def not the ideal way cause you can damage the pulley on the tensioner, so that's why I said be EXTREMELY CAREFUL doing it this way. But My belt has not slip whatsoever!! Also, Do you have the idler pulley on the SDCE bracket as loose as possible?? That will allow the most room for adjustment. Good luck.
Old Apr 30, 2013 | 07:21 AM
i have the sdce idler as low as possible , everything seems awesome now , just started it yesterday with no plumbing there to make sure nothing hit and everything seemed great .
Old Apr 30, 2013 | 01:04 PM
Inspector12's Avatar
TT-TECH Veteran
You don't need that dust plug won't affect anything. But the tensioner is off an 85 S15 blazer the Autozone number I use is 305201 its about 46-48 bucks.
Old Apr 30, 2013 | 01:40 PM
Thank you sir . I appreciate it .
