Anyone know where to get 1/2" NPT tap?
Old Apr 24, 2013 | 07:56 AM
703 CAMAROSS's Avatar
Default Anyone know where to get 1/2" NPT tap?
Im trying to tap a drain for my turbo into the pan but I can not find npt taps anywhere. Anyone know where to get them?
Old Apr 24, 2013 | 08:09 AM
Ping King's Avatar
Harbor freight has an NPT pipe tap set.
Old Apr 24, 2013 | 08:13 AM
Thanks!
Old Apr 24, 2013 | 08:15 AM
Chicago TDP's Avatar
Or Ace Hardware...I would go to ace, it will be a much better tap.
Old Apr 24, 2013 | 08:18 AM
MUSTANGBRKR02's Avatar
I have one I don't need anymore.
Old Apr 24, 2013 | 08:47 AM
LS1-IROC's Avatar
NAPA has them
Old Apr 24, 2013 | 08:48 AM
Striker289's Avatar
I bought mine and the correct bit for the tap from Amazon. Only took a few days to recieve it. only problem i had was my drill wasnt big enough for the bit. had to use my buddies drill press. My drain is in my timing cover.
Old Apr 24, 2013 | 09:10 AM
pwrtrip75's Avatar
Fastenal, Grainger, MSC, . Careful with the cheap harbor freight ones or the local hardware stores chinese knock offs, you'll tap 2 holes and they will be dull.
Old Apr 24, 2013 | 09:13 AM
Napa has one! Thanks guys!
Old Apr 24, 2013 | 12:28 PM
Need_a_Camaro's Avatar
Bring me the pan dude, and I'll weld a fitting on it for you.
Old Apr 24, 2013 | 05:17 PM
Vcious04's Avatar
Incorrect. For what it's worth my $9 NPT 6 piece tap and die set from HF (Even came with a nice wooden storage box) has tapped approx 100 different pans/water pumps and turbo piping with no failures whatsoever.
Old Apr 24, 2013 | 09:49 PM
knuts82's Avatar
Ridgid makes one Ive tried a few of the cheaper ones and they suck.
http://www.ebay.com/itm/Ridgid-35830-Model-E-5115-1-2-NPT-Pipe-Tap-Hand-Use-/370528712254?pt=LH_DefaultDomain_0&hash=item56453b763e
Old Apr 25, 2013 | 02:32 AM
95bowtie's Avatar
Well that sums up that debate whether or not the cheap ones suck. They may be worse if your using them in steel but aluminum is so soft I don't see it dulling a metal tap too quickly.
Old Apr 25, 2013 | 02:44 AM
birner88's Avatar
i have one right in front of me in my work toolbox lol
Old Apr 25, 2013 | 01:35 PM
turbo6man's Avatar
FYI: My local Napa stocks them(I have bought 2)
The Balkamp manf# p# is "T-304" 1/2" - 14 NPT (on box)
On website it is "BK t304" Napa online price is $17.34
The hard part for me was getting the proper drill size which is 45/64"
Good Luck
Old Apr 25, 2013 | 01:52 PM
93camaro_zzz's Avatar
I had to buy this item, I found it online, I just forget where, it has been 3-4 years.
Old Apr 25, 2013 | 03:17 PM
GMCtrk's Avatar
Good Luck
I have the 45/64 drill bit but a 23/32" will work too.
Old Apr 25, 2013 | 09:07 PM
I got a 45/64th from my local snap on truck that comes to the garage I work at. Thanks for the offers though!
Old Apr 25, 2013 | 09:16 PM
Italianjoe1's Avatar
For anybody else looking, www.mcmaster.com has anything you need like that and in different quality/price levels.
