oil relocation + cooler
Old May 16, 2013 | 04:51 PM
at1222's Avatar
Default oil relocation + cooler
I know this isn't an ls motor, but motor shouldn't matter for this application. Need answers asap please.
Does anybody see any problem with this setup? I'm pretty sure all the parts use 10an lines. I will be using a scavenge pump from turbo outlet but didn't draw that in the pic.
Parts:
Derale 35706 Premium Engine Type M Spin-On Adapter Kit with 20 x 1.5mm Thread Size
http://www.jegs.com/i/Derale/259/357...oductId=961946
http://www.summitracing.com/parts/ea...FTBo7AodmTIAwg
I want to use that Earl's thermostat because it has ports for oil temp and pressure gauges. Will they still get accurate readings here in this setup?
The only problem I see is that I can not find the remote mount plate (Derale 35729) In the correct thread pattern the z uses (20x1.5 I believe). Is this a problem or will it not matter since it's relocated anyway and I'll just have to use a different threaded oil filter?
Any help greatly appreciated.
