Which head gaskets for budget build?
Old May 22, 2013 | 12:08 PM
chevyforlife's Avatar
Default Which head gaskets for budget build?
What factory mls head gaskets will work on a 5.3 with 317 heads I searched for a few mins but found 10 different answers
Old May 22, 2013 | 01:18 PM
denmah's Avatar
Moderator
well the 317s muck it up for you
why not use the stock heads, 317s needlessly lower the compression imo
otherwise you could use stock ls1 steel gaskets that are 34 for the pair shipped off summit.
with the larger bore size head i think you will need to run the ls9 or 6.0 head truck gasket. wich are both double the price
Old May 23, 2013 | 01:56 AM
I forgot to mention I am boosted that's the reason for the 317s
Old May 23, 2013 | 09:55 AM
oange ss's Avatar
stock 6.0 MLS gaskets...but the compression ratio is already pretty low with stock heads, no reason to run 317's
Old May 23, 2013 | 10:16 AM
02anti_vnm's Avatar
Ls9 head gaskets hands down. There's no stock or after market gaskets that compare in my opinion
Old May 23, 2013 | 08:12 PM
badhombre's Avatar
don't forget that the 317's have 2.0 intake valves, where the stockers are 1.89. exhaust valves are the same though
Old May 23, 2013 | 08:48 PM
turbocamaro125's Avatar
If its a flat top piston 5.3 and stock 243/799 heads are 9.98cr 317's would bring it down nicely. But if its not then cr is gonna be pretty low
Old May 23, 2013 | 09:59 PM
Blackpanther99's Avatar
Yup 5.3 with 6.0 heads can bring your compression very low. What pistons are you using?
Old May 24, 2013 | 08:26 AM
ls1curt's Avatar
I've had very good luck with the stock 6.0 mls gaskets.
