Valve spring question.
Old Apr 26, 2004 | 05:14 PM
2001WS6Vert's Avatar
Default Valve spring question.
With the 2.95 pulley my car runs fine and pulls strong to 6000rpm (as high as I take it). When I put on the 2.75 pulley on the car runs fine until you get into it, if you do a race run it will mis-fire on several cylinders. The boost is appr. 9lbs@2.95 and 11lbs@2.75. Do you think the problem might be the valvesprings? The guy that did the heads said that they were 918's but I'm not sure, I thought the 918 had a blue stripe. These springs look just like the stock ones on my old heads. I guess it could also be a tuning issue because I made no other changes in the computer. Any thoughts?
Old Apr 27, 2004 | 06:47 AM
I'm going to put in valve springs. What kind should I get, 918's? I am going to consider the SLP rockers (what are they 1.80 or 1.85?). My cam is pretty mild for the setup (214-224, LSA 114, lift .523 in. .535 ex.) so do you think I ought to go with the rockers? I do like the good idle and power down low though and I see that Rob Raymer makes great power with a stock cam.
