CTS-v Dual fuel pump on E85 limit?
Old Jun 8, 2013 | 08:22 PM
tiznodd's Avatar
Default CTS-v Dual fuel pump on E85 limit?
I have the Vaporworx system, which is a Rick's Fuel Tank that uses a CTS-V pump and stand alone voltage controller. How far can these pumps go on E85? Would 800rwhp through a 4l80e be possible with a boost-a-pump and dual nozzle meth? I currently have 80lb injectors and would likely upgrade to ID850 or ID1000's, assuming these pumps will support the power. My voltage controller will send out 14-15 volts, which is a bit higher than the CTS-V factory controllers go in stock form. I'm not finding anything online and was hoping someone has some experience with this.
Thanks!
