LT's + Vortech = lean?
Old Apr 28, 2004 | 07:26 PM
Firewood's Avatar
Default LT's + Vortech = lean?
I have a question about putting LT's on my car with the vortech unit. According to Superchips I can't without making the car go lean is this true. They told me that I would have to reprogram the car and have it dynoed. Is there a less expensive way around this, or am I stuck putting shorties on it for now? There isn't a dyno in my area or at least any that people aroung here know of. Any help would be greatlt appreciated.
Old Apr 28, 2004 | 07:41 PM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
1) Yes if you make more power you need to give it more fuel
2) Then don't do headers.
3) Where you located?
Old Apr 28, 2004 | 09:10 PM
Firewood's Avatar
So even the supplied fuel pump and bigger injectors that come with the vortech aren't enough? I'm located in Cody Wyoming, the middle of nowhere.
Old Apr 29, 2004 | 12:05 AM
Trojan T/A's Avatar
I thought headers usually richen the A/F? I do know that even if you get shorties, you will need a new tune as they will through off the A/F.
Old Apr 29, 2004 | 01:01 AM
Crunch's Avatar
I can't tell by your post if you already have the Vortech kit or not. If you don't, then not to worry, there is a Superchips order form included with the kit (there is a checkbox for if you have headers).
If you already have the kit installed, adding headers will lower your boost by about 2PSI, and you'll pick up a few horses. You'll need to pulley back up to make real power, though, but don't do that without a retune.
That said, I don't trust the Superchips tune regardless. I lost 50 horses with superchips. I always recommend a custom tune for supercharged LS1's, the extra $300 or so is worth it in the long run.
Old Apr 29, 2004 | 07:55 AM
Firewood's Avatar
I already have the kit installed. I was told once that the program from superchips wasn't a very good one, but that's what come with it. Who or what company would you recommend for the custom install?
