1000whp intercooler???
Old Jul 15, 2013 | 07:23 AM
TNTramair's Avatar
im with Pray Hrd. im running the same size intercooler as him and untill someone can show me proof that it wont be as efficient as its $500+ counter part im gonna stick with it. hopefully my trash will be running soon and ill log some temps to see.
Taubr unit: do you happen to have a comparison in temps between your Treadstone and the ebay cooler by chance? you mentioned the Quality was better but didnt mention anything in regards to efficiency. just curious.
Old Jul 15, 2013 | 11:22 AM
Matt00's Avatar
Wow. Stock48 I didn't think our stock bottom would handle 20-25psi. What happened with turbonetics? I was planning on going with their turbo through Huron speed.
Old Jul 15, 2013 | 11:23 AM
Matt00's Avatar
All I can find on ebay is Godspeed ic's. is that what y'all have?
Old Jul 15, 2013 | 11:31 AM
stock48's Avatar
9 Second Truck Club
Yes they will but there is no room for error.
They were supposed to send me a prototype 76/75 to test against a my 76/68, and ended up sending me a 66/75 that was supposed to go somewhere else. So I next day aired it back to them so they could get it to customer and they drug me out for 3 months with no turbo then ended up sending it to someone else instead. I had dyno reserved, and held up my truck all summer for them along with paying over 100$ to ship that 66 turbo back for nothing. Not even a thanks....
Old Jul 15, 2013 | 01:14 PM
skinnies's Avatar
Running a treadstone twin setup 6" tall intercooler, it cools fairly good for not having great airflow on my car. I do have pre/post temp sensors and pressure sensors, seeing around 75 degree drop in temp and 1.5 psi drop of pressure is all at what should be over 1000rwhp.(163mph at 3440lbs)
Old Jul 15, 2013 | 01:41 PM
TNTramair's Avatar
thats the one i have and its a solid unit. car isnt running yet so i cant comment on how it performs just yet but looks wise, seems very solid..nice welds etc. i got mine for 160 bucks shipped....for 160 bucks im willing to take a chance. if it doesnt work out...ill fork over the big bucks for another..no biggie.
Old Jul 15, 2013 | 03:05 PM
Matt00's Avatar
That's a good point. $160 is a good price. Thanks for the info on build quality. Can't tell a whole lot from the pics but I may try them out and if its not up to my standards sell it and upgrade.
Old Jul 15, 2013 | 03:06 PM
Matt00's Avatar
Skinnies, where did you get your treadstone?
Old Jul 15, 2013 | 04:22 PM
Taubr Unit's Avatar
No, never ran it with the eBay unit, sold it mid-build for the Treadstone I have now. Just got the car running so no actual numbers yet. All I can comment on its quality. However the thing that I like the most on it is its a real 3" in/out with machined ends. The eBay ends are cast 3" so it's like a 2-3/4 in/out which I didn't like.
Old Jul 15, 2013 | 05:54 PM
Slowhawk's Avatar
LS1Tech Sponsor
I run the e-bay 4". Made bigger end tanks with 3.5" inlet/outlets.
Makes over 1000 rwhp at 19 psi through a t400 and ran 8.4 at 169 mph first day out. Runs faster 1/8's now.
It works.
Old Jul 15, 2013 | 07:36 PM
Matt00's Avatar
Good #'s and info. Thanks!
Old Jul 15, 2013 | 08:39 PM
  #32
deeloc1's Avatar
Treadstone trst9 1300hp a2a for $408 shipped from MAPerformance. Has a 9"x25"x3.5" verticle flow core.
Old Jul 15, 2013 | 08:40 PM
  #33
Taubr Unit's Avatar
It works.
This is the way to go if you have access to a welder and extra aluminum around.
Old Jul 15, 2013 | 09:00 PM
  #34
SPRAYED 01's Avatar
My ebay 4x12x31 sucks. At 25psi pre ic i only see 20psi in the intake. I made 835whp through it but how much am i leaving on the table? We will find out over winter when i buy a nice one
Old Jul 15, 2013 | 09:08 PM
  #35
stock48's Avatar
9 Second Truck Club
That's really not all that bad. I loose 7-8 psi on my truck. A couple of psi is just from cooling the air. And have to figure at least a psi in the piping if you have bends.
Old Jul 16, 2013 | 06:48 AM
  #36
TNTramair's Avatar
I agree with stock48...dont think thats all that much. but itll be good to have a comparison...please post up your results when you have them. im also curious to see how the temps compare between the 2.
Old Jul 16, 2013 | 05:54 PM
  #37
Matt00's Avatar
I agree I'm interested to see the numbers.
Old Jul 16, 2013 | 06:52 PM
  #38
TrickPerformanceProducts's Avatar
Truck Sponsor
20% drop seems hi.
But if your limited on space that's all you can do.
Old Jul 16, 2013 | 08:22 PM
  #39
SPRAYED 01's Avatar
I wish a good ic company made a 31x12x4. I can only find similar dimensions but they are either 4.5 or 5inch thick. Id really have to take out alot of bumper to fit that.
Old Jul 16, 2013 | 08:26 PM
  #40
stock48's Avatar
9 Second Truck Club
Extreeme turbo systems builds them to spec. I believe the little 3" cooler on my truck was made by them.
