throttle body boost leak
Old Jul 31, 2013 | 08:40 PM
User-c3's Avatar
Default throttle body boost leak
I did a boost leak test tonight and found a massive leak out the throttle body. Not sure the exact name for it, but its where the throttle blade shaft comes out and is sprung for the throttle cable. just blowing massive amounts of air.
Has anyone had this problem?
I just found it and have not tried to see if that comes apart yet.
What are the steps of repairing this. Is it simply just a seal that has gone bad?
Old Jul 31, 2013 | 09:52 PM
conan's Avatar
There is a seal and a bearing on that side of the throttle body. Remove the 2 screws that hold the blade to the shaft, open the TB to wide open and slide the blade out. The remove the throttle position sensor and remove the spring clip. Then pull the shaft out of the TB.
Old Aug 1, 2013 | 07:26 AM
User-c3's Avatar
Thats exactly what I was looking for. I figured of course there is a seal in there, just wasnt too sure. Always nice to know something ahead of time.
Old Aug 2, 2013 | 09:28 AM
User-c3's Avatar
Do you have any idea where to find just that seal? I cant seem to find it at any dealer or parts stores
Old Aug 2, 2013 | 02:45 PM
conan's Avatar
Do you have a bearing store in your area ? I have a place near by me... McGuire bearing, they match me bearings and seals all the time just from measurements.
