Boost control Help
Old Aug 4, 2013 | 02:08 PM
Half-bred's Avatar
Default Boost control Help
I have a 370 with a 76mm and I'm running a 38mm synapse wastegate My question is I'm in the process of hookup a Daytona TC1 boost comtroller, But I'm pretty sure I'm getting boost creep, I'm trying to start off with like 3-5lbs and then ramp it up. But should I run another 38mm or would a 50mm do the job, And Just to male sure I have it hooked up right does anyone have the same or similiar setup. Thanks for any input.
Old Aug 5, 2013 | 12:12 AM
itsslow98's Avatar
A 50 should do it but make sure the placement is perfect the way it is. I would say the 38 is too small for that low of boost on that setup no matter how its mounted.
Old Aug 5, 2013 | 01:36 PM
PerformanceEngineer's Avatar
Restricted User
What is your spring pressure?
Old Aug 6, 2013 | 09:20 PM
Half-bred's Avatar
I have the 45lbs spring in the wategate and the hose from the boost solenoid going to the C port of the wastegate.
