Engine build decisions. Cam or CNC heads?
Engine still runs but has a nice rod knock. I had TMS build a 313ci forged piston motor. 3.9 bore and 3.27 stroke. It should make peak HP at 6500rpm.I have enough $$ to have TMS CNC port my 799 heads or a turbo cam and hardened push rods. I currently have a LS6 cam and good valve springs and retainers.
I hope to make 550rwhp at 8/9psi.
I am leaning towards the cam and push rods because I need rpm to take advantage of the short stroke and hope to have a reliable 7000rpm rev limit.
Thoughts? FYI car weighs 3278lbs in street trim and has a t56, 373 diff and 25" tire.
You are a very humble person to recommend me so freely! I respect that a lot!
OP I have a ton of emails and PM's right now to answer, so please accept my apology in advance that I may not be able to answer your questions for a few days. Hang tight and I will get you the best camshaft possible for your combination! It will be worth the wait!
