Help! Steering Knuckle Clearance!
Old Aug 12, 2013 | 08:48 PM
ws6fitz's Avatar
Default Help! Steering Knuckle Clearance!
I need some help on this. I am installing a turbo setup on my 01 Trans Am and the piping is hitting the steering knuckle on the stock k-member. Is there anyone that makes a modified steering knuckle or something I can do to it? I really don't want to go to a manual steering rack. Any suggestions and pics would be appreciated!
Old Aug 12, 2013 | 10:17 PM
ws602's Avatar
Check out Flameing river
Old Aug 12, 2013 | 10:24 PM
SPRAYED 01's Avatar
I have a flaming river kit new in the box. Pm if instated. Its basically a low profile steering shaft to give you more room
Old Aug 13, 2013 | 10:12 PM
ws6fitz's Avatar
Sent you a pm.
Old Aug 14, 2013 | 08:43 AM
CALL911's Avatar
You should be able to move the steering column over a bit also. I had to do this when my steering knuckle was hitting my Kooks headers. I was able to move it enough so that it cleared. Mine wasn't clearing only by a bit, so it will depend on how much clearance you need, as you can only move it so much.
