Timing maps...
Old May 1, 2004 | 12:18 PM
What's Avatar
Default Timing maps...
Does anybody on here have a rough idea of what the stock timing maps are in the ECU? 18 degrees base plus ECU maps... any idea of total crank degree timing values for full load at different rpms? Anyone measured actual degrees with appropiate timing gun while full load on dyno? I've done this on other cars on Dynojets seperate program holding the rpm/speed and it's very very nice to know the actual values (huge locomotive brake on dynojet still allows to abuse the dyno as such).
