fairmont 3.0 (5.3, isky 3x12, s476r) 721rwhp @ 17psi pumpgas 9.68@145mph
Old 08-29-2013, 06:16 PM
  #81
SUTTERERMAN85's Avatar
Originally Posted by typhoon1015
Wonder what they are made out of and spring pressures...
Old 08-29-2013, 07:49 PM
  #82
kevin99hoss's Avatar
I love the video updates, keep up the good work
Old 08-29-2013, 08:59 PM
  #83
gofastwclass's Avatar
Me too. They look and are priced strangely like the last set of LS6 springs I bought minus the packaging and blue color...
http://www.summitracing.com/parts/nal-12499224
If they work well for more lift and boost, good sloppy find.
Old 08-29-2013, 10:43 PM
  #84
Moderator
denmah's Avatar
Old 08-29-2013, 11:07 PM
  #85
slowbu's Avatar
Are we going with fender exit exhaust this time as well...hehe
Old 08-29-2013, 11:09 PM
  #86
Moderator
denmah's Avatar
Old 08-29-2013, 11:10 PM
  #87
Moderator
denmah's Avatar
well thru the inner fender, then down under in front of the tire is what i like to do most.
Old 08-29-2013, 11:11 PM
  #88
Sumter's Avatar
Good deal. I've been wanting to reduce my crossover down to 2" aswell for quite a while now. Can't wait to see how it works out
Old 08-29-2013, 11:16 PM
  #89
Moderator
denmah's Avatar
if it lights fast even with stock cam and converter i know we did something right!
this actually has a beautiful merge, well, might not look great to some of you but both sides merge evenly into the t4 flange in a totally unsloppy mechanics manner
Old 08-29-2013, 11:24 PM
  #90
Sumter's Avatar
I think it's going to work great. What wastegate is that and what size?
Old 08-30-2013, 12:08 AM
  #91
Moderator
denmah's Avatar
its a china 60mm from VSracing
its like a little larger than 2.5 inch inlet and 2.25 outlet
Old 08-30-2013, 08:21 AM
  #92
Ironfreak's Avatar
Man I love watching your builds. I have been building a bmw and was going to keep it all Bavarian until my buddy kept pushing the ls1 idea. I've read through almost all your builds and will be following this one extra close. I picked up an lm7, have some big injectors and am looking for a turbo.
Keep up the awesome work man!
Old 08-30-2013, 08:25 AM
  #93
merim123's Avatar
how do you feel about that weld on the exhaust manifold to the thin wall exhaust pipe. Read a lot about issues guys are having because they don't preheat, curious if you've seen/had any issues and if you are preheating at all.
Old 08-30-2013, 09:04 AM
  #94
Ironfreak's Avatar
With the 2" pipe on the hot side when do you expect to see full boost on the 76mm? What kind of feel are you hoping for with running the stock converter?
Old 08-30-2013, 10:36 AM
  #95
turboventura's Avatar
Have you thought about keeping it twinscroll and two smaller gates? Cant believe you still have the motivation to keep ripping out builds like this, keep it up man.
Old 08-30-2013, 11:19 AM
  #96
Moderator
denmah's Avatar
thanks!
check out my commonly bought items thread if you wanna get something or feel free to bump it and ask, i should go thru it sometime again
never pre-heat and i never have any problems welding mild steel right to the manifold
i was hoping to edge into the 10s on stock cam and converter, might be asking alot but will be fun to try eh?!
it would be cool to see lots of boost under 3000! i have no idea what will happen though
well this turbo is open T4 flange not divided. so not really twin scroll
two small gates not worth it for this thing IMO
Old 08-30-2013, 11:32 AM
  #97
brewster240's Avatar
hey sorry if you said already, but have you been reinforcing the torque boxes at all?
Old 08-30-2013, 11:57 AM
  #98
Moderator
denmah's Avatar
nah i never do, my cars don't launch hard
Old 08-30-2013, 08:44 PM
  #99
kainedogg's Avatar
Definitely want your opinion on the 2" cross over piping. I know Corky Belly endorses it but I need real world testing...and that's where you come in. If you say it works then I will do 2" to run the VSracing GT45 Hong Kong Phoeey turbo.
Old 08-31-2013, 08:15 AM
  #100
Beatdown Z's Avatar
Here's a little thread from the bullet about crossover piping size: http://www.yellowbullet.com/forum/sh...d.php?t=594198
Makes me want to redo all my current turbo setups. haha
Quick Reply: fairmont 3.0 (5.3, isky 3x12, s476r) 721rwhp @ 17psi pumpgas 9.68@145mph
