Going Turbo a few questions about current setup
Old Sep 6, 2013 | 10:26 PM
Jwilliams04's Avatar
Default Going Turbo a few questions about current setup
I currently have a NA setup and going turbo. My cam is a 239/247 113 600 lift cam. Motor is a 402 with 10.5 comp. Do I need to change cams of will this be okay. I have read a lot of info but all say different things.
I also need to know what injectors to change to from my fast 46lbs to run 10lbs / 750-800 rwhp? 110 Race fuel/ no meth. What boost controller is everyone running.
Old Sep 7, 2013 | 07:41 AM
samdogmx's Avatar
i dont know on the cam, but you probably wont get to that HP with 46# injectors unless your cranking up the pressure insanely high. I would look into some siemens deka 80lb if you want to stay on gas, bigger if you think you'll do E85
Old Sep 7, 2013 | 08:41 AM
mrstepheneades's Avatar
Just get the FIC1000cc injectors lol. They are 95s at 43.5lb fuel pressure, and 103.5s at 58lb ls1 stock pressure. You'll need at least an 80lb injector to safely get that power level.
