Collin Patton's Trans Am 408ci, 88mm build thread. ( it runs again)
#44
Honestly a 3.42 or a 3.55 with a 4l80e would be ideal as a 3.08 gear is a TON of gear for turbo big block or nitrous big block to pull around let alone a small block no matter what size turbo is on it.
Compromises have to made though with street cars. I say TH400, 3.23 rear gear, 315/60 and cruise 70mph@2500rpm all day long.
#45
You don't need such high gearing with a massive compressor like that. Inertial load really only helps compressors that are too small where they have to build a substantial amount of boost before being able to move a large amount of air efficiently. Relatively larger turbos can still move a lot of air without having much/any boost, so the high load/long gear requirement is unnecessary. Now if you're looking for something more highway friendly that doesn't spin the **** out of the engine to cruise at 75mph or you're out of gear at your desired redline before crossing the traps...then I can understand the higher final drive
#46
#48
Right now it has a 4.00 gear in it. But I already had plans to have different gear ratios all set up and ready to drop in it for whatever reason. Whether going on a long trip or if I was racing in an 1/8th mile vs 1/4 mile
#49
Got Collins turbo braced up this morning before work once he decided where he wanted it sitting lol. A custom radiator will be made for this setup so we are not really worried about fitment as much as we would be normally. There is still 6-7 inches between the bracing and the back of the bumper/intercooler. Lower factory radiator support is still going to be cut out.
David is making custom chromoly exhaust flanges since we don't have any for the y pipe.
#53
I hope this is not off topic, but what did Work Turbochargers say when you found out that you did not have a S588 as he originally told you it was. I am just curious on how they handled the situation. He as well as our own Forcedinductions.com, was one of the companies I was looking at to purchase my turbo from. This could sway my decision. lol
Back on topic though, the build looks like it is coming along nicely! That 408ci + 88mm is going to pull like crazy!!! Can't wait to do the same with my car!
#54
#55
That is correct. I bought it from a guy that bought it off a drag car he sent it to the works and had it refreshed but hasn't done anything with it in over 2 years and then sold it to me. Once I called the works and told them what car it was on previously he told me exactly what turbo it was and everything about it. It's just the guy I bought it from wasnt very knowledgeable about the turbo that's been laying in his garage for 2 years.
#56
