Oil pressure sensor adaptor.
Old Sep 16, 2013 | 10:12 PM
KissMySSo1's Avatar
Default Oil pressure sensor adaptor.
Does anyone know of a company that makes an oil pressure sensor adaptor to run an oil feed? This is for an LS3 style oil pressure sensor in the valley cover. the thread is M16 x 1.5
Even if someone knows where I can find a couple steel unions I can weld up would be great. Some reason they're MIA everywhere I look
Old Sep 16, 2013 | 11:40 PM
NightmareTA's Avatar
Same one I used
http://www.summitracing.com/parts/atm-2268
Old Sep 16, 2013 | 11:41 PM
denmah's Avatar
Moderator
i got the same thing just shipped from amazon
ballin'
Old Sep 17, 2013 | 12:12 AM
KissMySSo1's Avatar
Thats not going to work. I need an extension that will allow me to still use the sensor.
A fitting that has a male M16 x 1.5 on one end and a female M16 x 1.5 on the other. An a port on the side where I can run an oil feed whether it be a male -4 or a female 1/8npt
Old Sep 17, 2013 | 08:33 AM
geoff17's Avatar
http://www.summitracing.com/parts/equ-9848
has that same fitting above for cheaper plus a bunch more.
Old Sep 17, 2013 | 08:36 AM
geoff17's Avatar
Sorry OP I know that doesn't help you, not sure they make anything like that, if you were using a sender that was 1/8 npt like an autometer you could just use a y adapter fitting and run an line to your feed for one y and another an line to the sender.
Old Sep 18, 2013 | 08:54 PM
ta02zx10r's Avatar
Where's the oil sensor located on ls3's. I know that Kurt Urban sells something like that. I checked their site but I don't see it on there anymore. It might be worth a try to call them. It's an adaptor that goes under the sender and has two ports for feed lines.
