Lambda for Meth Injection?
Old Sep 30, 2013 | 04:48 PM
Ferocity02's Avatar
Default Lambda for Meth Injection?
When injecting methanol, or a water/meth mix, what lambda is good to aim for? I'm using lambda here because its value should apply to everyone no matter what fuel/mix you're running, at least in theory. Obviously the ideal lambda may depend on the setup but is there a rule of thumb?
I'm injecting 50/50 water/meth at 15gph and aiming for around 0.78 lambda. My timing is around 16 deg, boost is 10-13psi. I heard 20% rich (lambda 0.80) is good goal, so I went slightly richer to be safer since it's my DD.
Old Oct 1, 2013 | 02:32 PM
Beatdown Z's Avatar
.76-.78 Lambda is what I shoot for(with or without meth).
