Precision PT 76GTS turbo Lm7?
Old Oct 4, 2013 | 10:17 PM
Boneyard buick's Avatar
Default Precision PT 76GTS turbo Lm7?
Hey all, currently I'm turbo shopping for my 2000 Lm7 5.3. Stock bottom end, will have 80# injectors, re gapped rings, ARP hardware, custom grind cam, flipped truck manifolds, ls9 gaskets, truck intake setup and it's all going into my 85 regal. It's going to be a street car, but should see a few track days. Im wanting to make a solid 550+ HP at least.
I just need some help whether or not to try this thing out on the 5.3, I've read a few builds and it's a pretty good turbo on 347, 357, 370 strokers but is limited to about 20psi because of the turbine. Will this be a good choice for the 5.3 being a 325ci?
As far as I know It's a PT 76GTS, T4 flange, 0.96 AR, 4" in 3" out
What can I expect out of this turbo?
Old Oct 4, 2013 | 11:21 PM
JohnS Z28's Avatar
it should be easily attainable, it seems like your optimizing for boost (custom boost cam?) should be making great power on a 5.3 even a 4.8, especially if you plan on 20 PSI
Old Oct 5, 2013 | 01:07 AM
Mrmooney's Avatar
My turbo camd lm33 5.3 799s stock with ls6 intake th400 moser 9inch made 715 /668 on 16psi corrected due to elevation with .81ar housing. Its losing power after 5700 hoping due to ar housing being small one. I just swapped the. 96 housing on it hoping to get tune next weekend. Same turbo 7675gts
Old Oct 5, 2013 | 01:21 AM
Nice numbers for a .81!
Old Oct 5, 2013 | 01:23 AM
Mrmooney's Avatar
Really hoping this .96 helps a bunch
Old Oct 5, 2013 | 01:28 AM
Havent read much on the .81 but the .96 seems to be a great turbo, few guys cracked 900rwhp when they said it couldn't be done. Suprising.
Whats your cam specs?
Old Oct 5, 2013 | 01:51 AM
Mrmooney's Avatar
This is on E85 also forgot to mention that . Lil jhon specd cam id have to dig out cam card.
Old Oct 6, 2013 | 12:26 PM
Mrmooney's Avatar
Should be tuned next week ill let you know how it does with bigger housing
Old Oct 6, 2013 | 05:34 PM
Ryans99ls1's Avatar
pt76 and 5.3 is a match made in heaven. its a record holding combo
Old Oct 7, 2013 | 08:50 PM
LS1NOVA's Avatar
Yep yep, great match. Mine made 711w on 17lbs and who knows on 23 but it felt real good.
