How much Pump with e85 and turbo?
Maybe alternator, maybe wires to pumps are too thin. Something. Try hooking up a volt meter and reading it while you go into boost (Have passenger monitor it while you drive). See if there's a voltage drop.
I'm starting to think the primary pump is the only one working and not the secondary. I might also remove the alternator and take it to be tested as that is pretty easy to do.
A regulator is a mechanical component. With no vacuum lines attached it should be able to hold a constant pressure regardless of flow. Often a failing regulator won't let it be set to a constant pressure or even a high pressure at all. Pressure dropping when the car goes into boost isnt a sign of a failing regulator when the vacuum line is unhooked from the regulator.
