flex-piping for Charge pipe?
Old Oct 30, 2013 | 07:41 AM
BMF_Racing's Avatar
lol !!! theres one of these threads on yellowbullet now. Funny to read for sure!!!
Old Oct 30, 2013 | 08:09 AM
Twin turbo c5's Avatar
Yeah don't use that stuff . You should be able to get a few bends and weld a pipe together in there. I've worked in tighter places building a kit for a c5 corvette. Or reduce down to a little smaller pipe using a coupler.
Old Oct 30, 2013 | 08:47 AM
HRHohio's Avatar
Use 2" piping...
Any issues with flow in a 2" pipe (pre-intercooler)? What about post intercooler? (For say, 700-1000 rwhp build).
Old Oct 30, 2013 | 08:50 AM
Forcefed86's Avatar
For the OP’s build suuure. It’ll be fine. May not be optimal, but the mans using fence post to put a turbo kit together. I’d say if it makes positive manifold pressure at all, it will be a win.
Old Oct 30, 2013 | 09:06 AM
Ron_Stoppable's Avatar
Lol fence post?
Old Oct 30, 2013 | 09:15 AM
HRHohio's Avatar
Lol. Actually I meant just in general. 2" Charge Pipe or 3". Which is better? Does it matter that much?
Old Oct 30, 2013 | 09:47 AM
Forcefed86's Avatar
Originally Posted by Ron_Stoppable
Lol fence post?
First thing that cam to mind when I saw this...
Thats a serious peace of hardware for charge piping! Whats that thing weigh?... 40lbs?
Depends on several different variables there is no black and white answer. Would probably be fine on a mild lowish boost setup. The turbo will just have to work harder to push the charge through smaller pipe.
Old Oct 30, 2013 | 12:48 PM
Lol no no no. Its just coincidental lol. The tubing on the ground is 11 gauge mild steel. Ive been really thinking of just cutting out some of the floor. I want to run 2.5" piping. I plan on running max around 15lbs of boost.
Old Oct 30, 2013 | 01:48 PM
Forcefed86's Avatar
Why not grab some 18g mild steel, use 2" and run it through the cab, you'll be fine. Just beat the crap out of it anywhere it won't fit. If you want "bendy" cold charge piping look up SCEET hose. I used it on my setup a long time ago... I'll never admit to it in person though.
Not cheap, but it's rated for the heat and pressure.
. The 2.5 inch ID tubing that I used was temp. rated at -80-520*f. And has a max working pressure of 40psig. and a burst press of 140psi. Inside the 2 walls of tubing there is a spiral round steel wire so the tubing keeps it's shape.
http://www.aircraftspruce.com/catalog/appages/sceet.php
Old Oct 30, 2013 | 02:08 PM
Will 2" affect the performance detrimentally? Will it cause lag?
Old Oct 30, 2013 | 02:32 PM
Forcefed86's Avatar
No smaller tubing will not cause lag. It will make the turbo work harder and raise the charge temp a bit. At the boost levels you’re talking about I wouldn't worry about it.
Jeebus man I'm all for helping, but go read a turbo book (or 2) before you attempt this!
Old Oct 30, 2013 | 07:40 PM
  #32
Lol...........
