question about back pressure?
Old Nov 14, 2013 | 07:58 PM
2000RATA's Avatar
Mine in 1st gear still makes boost even spinning. Mine makes boost at 1/2 throttle pulling away from a stop sign and by the time I clear the intersection it's let off or hold on. You got something going on.
Old Nov 14, 2013 | 08:34 PM
SPRAYED 01's Avatar
Do you have a Filter right on the turbo or is there a pipe with a silicon connection? Could that be sucking shut?
Old Nov 14, 2013 | 08:48 PM
SSZ's Avatar
SSZ
The small exhaust leak in the one manifold willl not help things. That allows exhaust pressure to exit instead of going to the turbine. Get that fixed. Then go from there.
Old Nov 15, 2013 | 07:21 AM
SPRAYED 01's Avatar
A small leak won't cause 0 boost. But fix it any way
Old Nov 17, 2013 | 12:49 AM
brianfromhawaii's Avatar
I do not have an air filter... 2000RATA, you have twins right? I have one big *** s480 with a 96mm turbine
i need to address my cooling issues before anything else... thanks for all of your help guys
Old Nov 17, 2013 | 08:34 AM
2000RATA's Avatar
Yes I have twins. They are basically the equivalent of a good single 88. I am running 378 cid.
