My S10 5.3 Rear mount
I quickly swapped out the 5.3 4l80e out of my old truck and put it in this one in about 2 days lol. The 5.3 is fast but I'm ready to make boost. This was a spontaneous over night decision also haha. Truck has a
5.3
228r Comp cam
PAC 1218 springs
Ls1 intake
4L80e trans
3200 278mm Circle D stall
I'm using a GT45 Turbo mounted behind the cab
-GT45 Turbo
-Siemens 60lb injectors
-Snow Performance Methanol kit
-AEM Boost gauge
-Aem Digital Wide and Gauge
-Dr.phil tune
-Walbro 400
-Ebay Wastegate
-Ebay BOV
-Shurflo 643-210 Scavenge pump
I'm hoping for 500 - 600rwhp or more! This is my DO so I'm probably gonna keep it between 10 - 10 psi of boost.
[IMG]http:
//i223.photobucket.com/albums/dd146/IxGODL1KExI/20131031_104212_zps402b7160.jpg[/IMG]
-10an drain fittings with a bridged oil check valve
picked up a FORD 8.8 rear end for $150!! It's a 3.73 position locker with disc brakes from an explorer.
pulled the a lesson to have them redrilled for a chevy pattern.
It's nice and stout. I also bought a holley accessory bracket kit from a friend. It was brand new. Bought a 3 gauge pod from a friend for $20 also. I HAVE my scavenge pump on the way along with 12ft of -10an stainless braided hose and 12ft of -4 an hose for the feed.
Do yourself a favor measure the drain hole on the turbo itself. Don't go any smaller than that for the drain line into the sump. My guess is -10 is no where near large enough for an optimal setup. The -12 fitting I had was much smaller than the required 19cm basically 3/4" hole in my last setup. (yours may be smaller)
Good luck looks good!
