Turbo 5.3 heads?
Also, I'll be running the On3 non A/C kit with there 76mm turbo. 4l80e and 3'42's.
That being said any stock LS head will make 600-700hp with a decent turbo setup. 243's aren't going to give you 400 extra HP or cause you to build boost off idle. Save your money would be my input.
317 heads have larger runners and larger valves and can usually be found for around $100. Best bang for the buck IMO worked great with my setup.
I guess the stock heads will go on first and I'll see how they do. I'm hoping to run about 12-14lbs at first and run gas only(93). Do you think that's enough to get me above 600whp? Future will be gas with meth and as much boost as she can hold.
You don’t want high compression. Especially since your using pump gas. You only lose 4-5% power NA per point of compression dropped. So if your at 300hp NA at 9:1 dropping to 8:1 will cost you a massive 12 hp. It’s not a night and difference. It’s a very small price to pay for the additional 12-15% more power you will be able to make with the additional boost it will allow you to run.
243’s have the same valve size and intake/exh port volume size as a 317 head. The major difference I am aware of is the 64cc chamber VS the 317’s 72cc. I believe some had better valve material or castings, but that doesn’t make them worth 3.5 times the price of a 317 head IMO. Run 5 more lbs of boost and buy a 317 head would be my suggestion. If the hotside is sized correctly boost will build very quickly. If you have some money to spend on heads buy a nice set of aftermarket or OEM worked over heads that are CNC ported with larger valves.
I ran a dished piston LM7 as well with 317 heads. 8.6:1 compression ratio. Easily making over 800hp at around 24lbs with an OEM cam. It built boost very quickly and was useless on the street at anything above 13lbs of boost.
Also spending money on rod bolts isn't necessary IMO. I and many others have all ran OEM hardware on the bottom end at higher power levels than you are talking about with no issues.
