Opinions on the F1-X
'00 WS6
LS2 365C.I.
10/1 C.R.
PRC stage 2.5 ls6 heads
ECS spec'd "big" blower cam
Meth Injection
80# injectors
Have you turned the d1sc up to at least 100% yet? If not, I'd do that until switching blowers. I spun a D1sc around 106% (with no belt slip) on a 347 and it made around 800rwhp. Where you at?
A cog setup would be ideal for it, and the ATI super pulley would aid in keeping the cog belts from snapping.
Fuel system would need to be able to support 1100-1250rwhp at least.
'00 WS6
LS2 365C.I.
10/1 C.R.
Meth Injection
80# injectors
I say go for it....when it comes to boost, bigger is better...if your engine can handle it
at 10:1, you are going to run into issues pretty quickly....
consider a thicker head gasket to lower your compression some
80lb injectors (rated at 3bar?)will be pushing it, but they will work as long as you dont try to make too much boost
only you will be able to determine the Fit...but it is pretty big, so you gotta be prepared to change some things around to make it work
Dan Shoneck(shoneck composites) makes a nice cog setup for an f1 with an LS engine... you will also need a CBR alternator relocation bracket, and you might have to make some changes to the power steering(I cant remember for certain on that part)
you may also need the ATI super pulley sprag cog for street driving or if you need to peddle the car at WOT otherwise you will throw belts
or you can try to keep it a 10 rib/12 rib setup and hope it slips a little when you need it to
definitely call procharger to get a suggested pulley combo to get to the desired boost value....
or just pulley to spin it as hard as it will go, and add a wastegate to the equation to control overall boost levels.
it will be good for closer to 1200 HP, and you dont need a 6 bolt block...though it certainly doesnt hurt to have one
Kurt
Kurt
Lots of people saying the same thing as you and that procharger is under rating this blower! Hearing that it is more capable than the f2.
