Finally got my car on a Dyno Monday after a long and stressful year. Its still has a ways to go to be finished but here it is. lq9 w 317s, ebay gt42, ls6 intake, 80lb injectors, 340 in tank pump, th400, 3400 stall, and a Jeff Lowry cam. Right now its tuned at 9 lbs on pump gas and waiting to dyno it again and turn it up,but first have to make sure its not hurt. little bit of metal in the first oil change has me on the rag..... BUT its my fault since I didnt wash my heads down after they came off a engine failure w a spun bearing and going to hope its from them and not a engine failure. oil pressure is still a solid 40 hot idle and 66+ up in the rpm's. I was stupid, didnt think and in a rush....
next step if after a few more oil changes the metal disapears (have been told that metal in a new engine is common during break in) its back to figure out the flat spot from 5500-7000rpm
A really big thank you to my cousin Kevin who helped out a lot
