SD-Concepts 6 rib questions.....
Kyle
Wendy
SHE IS WATCHING
Hi Wendy, I was talking about the adjustment tool, yeah thats it
I can't wait till its here. Gotta love that customer service
Bos, I went with the 8 rib set up, no more of that 6 rib stuff.
Anyone want a cog set up I don't have the time or resources to figure out the correct belt tension for the cog belt. $250 and its yours comes with everything, new cog belt and all.
J
What boost are you shooting for?
Its not really a boost goal im shooting for..... its a rwhp goal..... i want 600rw..... If Heaths friend can see 10 psi at 5800 with the same cubes as me and you then there so reason we cant do it and make a few more a little higher up in the rpm's. I dont know about you but my old setup started making really good boost up top and the last few hundred rpm's it picked up alot of boost and the same should happen with this setup. If we can do that and see no slip then i will be happy....... then comes the other problem..... how to put that power to the ground.....................
Heres a ????? to you and Jer... cant you sent the Cogs back and get a refund instead of losing the $$$ you paid for them..... if the product doesnt work isnt that fals advertisement??? Laterz im out for the night ill check this tomorrow.
Kyle
So that's why I put the call in for a sd-concepts set up, they have a tool for belt adjustment(which I bought-Thanks Wendy
), I have seen great reviews from the LT1 guys on cz28.com and from a couple people here. So I don't feel like I am trailblazing with this set up which is good.....and if it doesn't make 15 psi, **** it I'll spray it, whatever boost I see and a 100shot, that ought to do it
I am just tired of dicking with s/c belt problems.J
SD was afraid that I was going to have clearance issues with the 6 rib s/c belt and water pump pulley....his reasoning is because the MMS pulley is so big? So I guess that will go up for sale.Man decisions decisions.
J
Maybe you can get SDCE to make you a larger crank pulley? I know the ones they have are 7.2 and they have 6 ribs and 8 ribs if I remember right, just a thought.
J
