Which head gasket
Old Dec 26, 2013 | 03:02 PM
11SECSS's Avatar
Default Which head gasket
Okay my motor is a stock LS1 long block with 77k on it took the heads off to have a valve job and new comp 918 springs also adding a LS6 cam .Was wondering which head gaskets to use GM MLS 12498544 or the LS9 12622033 which has a 4.1 bore ? The stock gaskets seemed to work just fine before taking off the heads. Motor is making around 8 psi but might take it up to 10 with a smaller pulley and the aster bracket I picked up (hopefully no more belt slip).
Old Dec 26, 2013 | 03:08 PM
Twin turbo c5's Avatar
ls9 I've used them for years at 20psi or more . Defintly the way to go.
Old Dec 27, 2013 | 08:50 AM
samdogmx's Avatar
since its a small bore motor & your talking low boost I'd stick with the stock gasket. The bigger bore of the ls9 will drop your compression a wee bit & IMO is not needed at only 10psi
Old Dec 27, 2013 | 10:24 AM
ls1curt's Avatar
Just stick with the stock gasket. It will be fine.
Old Dec 27, 2013 | 04:05 PM
11SECSS's Avatar
thanks a lot guys ,I'm going with the stock GM MLS ones .
