LS2 to LSA conversion
Old Jan 3, 2014 | 09:32 AM
Airboat Chris's Avatar
Default LS2 to LSA conversion
I have a carb fed ls2 and I would like to install a lsa/zl1 supercharger. I realize I have to change the heads, get the proper wiring harness as well as get a lsa/zl1 supercharger. I have seen where some changes have been made since 2009. Does that effect the harness and supercharger I would have to buy? meaning do they have to match year wise? For instance would a 08 charger work with a harness for a 2010?
I have also read where there were a ton of these replaced due to a isolater rattle and that GM requested all cores be returned to GM. Is GM rebuilding these units and offering them to be sold as rebuilt?
Lastly I know the ZL1 top hat is on back order and everyone I've talked to doesn't have a ETA. Does anyone here have any insight as to when it will be available again?
Thanks for any help!
Old Jan 16, 2015 | 03:21 AM
Rainmaker6's Avatar
Default LSA conversion
Did u ever go through with the conversion ? I too have an Ls2 and i want to convert over to the lsa charger....i know i have to change heads and cam just stock on what else like brackets and pulleys. PLEASE HELP Thanx...
