Knock sensor?? Boosted application
Old Jan 4, 2014 | 09:56 PM
nhra_crazy's Avatar
Default Knock sensor?? Boosted application
Is there a benefit to running or not running knock sensors on either a single or twin turbo setup? Any thoughts would be great. Thanks
Old Jan 4, 2014 | 11:31 PM
SPRAYED 01's Avatar
You should run, benefit is knock detection. If you log runs it will give you an idea of when the knock is so you can change things like fuel and spark to correct the issue.
Old Jan 4, 2014 | 11:32 PM
SPRAYED 01's Avatar
Can you get away with not using them? Sure but why would you if you are already using a computer and fuel injection.
