Need help with piston rings??
Old Jan 9, 2014 | 12:49 AM
bmr408's Avatar
Default Need help with piston rings??
I need a set of rings for my 434. Its 4.155 bore. I'd like file fit. I will be running a lot of boost. What would be best for my application? Is steel top ring a must? I have used total seal steel top ring package and am not real happy with them. Just would like to see what everyone else is running? If you could please leave your recommendations with part numbers that would be great! Thanks!
Old Jan 9, 2014 | 02:23 AM
coolmanvette75's Avatar
Yes I would say steel top is a must. Different bore size but I'll be running a Total Seal set with a gapless steel top ring, napier 2nd ring, and standard tension oil ring...
Old Jan 11, 2014 | 06:18 PM
BOTTLE ROCKET's Avatar
What didn't you like about the TS steel set?
Those are the rings a builder wants to run on my build
Old Jan 11, 2014 | 06:50 PM
Burken01's Avatar
X2 I have them
What don't you like about them Op
