Turbo PCV Help
Old Jan 16, 2014 | 11:49 PM
LSM3's Avatar
Default Turbo PCV Help
So I did not have the foresight to setup my PCV system for the newly added turbo and I have to drive the car to the exhaust shop tomorrow. I just need a easy fix to my setup before I do something permanent.
My current setup has the rear ports on both valve cover plugged. The passenger side front port is connected to the throttle body. The LS6 Valley cover has an integrated PCV and is connected to the intake manifold.
What is a quick and easy way to set the PVC system up? Im thinking breathers on the valve covers with a one way valve between the LS6 valley cover and the intake manifold. I would probably just plug the throttle body port.
Any help would be appreciated...
