In-cabin boost controller
Assuming your in the ball park with the spring in your gate all you need is a dual port wastegate, length of vacuum hose (silicone is best) and this regulator. My gate came with a standard 10lb spring. (I’d see 9 on my boost gauge on spring alone) I had a range of 9-20psi with this ****. I had to up the size of the spring in the gate to get more than 20psi.
You would remove and plug the gauge. The **** has a nice locking feature. You pull the **** up to unlock and turn it clockwise to allow more boost to reach the top WG port. That will increase the boost. Allowing no pressure to the top port will give you your lowest boost.
http://www.ebay.com/itm/MINI-Pneumatic-Air-Pressure-Regulator-1-4-BSPT-w-Gauge-750L-min-AR2000-/370723699329?pt=LH_DefaultDomain_0&hash=item5650daba81
Mini Pneumatic Air Pressure Regulator 1 4" BSPT w Gauge 750L MIN AR2000 | eBay
I've haven't seen a "touchy" setup done like this with these regulators. Usually a half to 1/4 to 1/2 turn turn for a pound increase. I've never seen a relief type regulator small enough to go in place of a cig. lighter? Are you using a "boost bleed" type of control? They can be very touchy.
I like this setup. I've used it quite a bit. (pretty cool website too. wasted alot of hours there!)
http://www.autospeed.com/cms/A_111348/article.html
Here is another way, very cheap and easy, But requires a bit of trial and error tuning so you don't over boost initially.
I've never seen a "touchy" setup done like this with these regulators. Usually a half to 1/4 to 1/2 turn turn for a pound increase. I've never seen a relief type regulator small enough to go in place of a cig. lighter? Are you using a "boost bleed" type of control? They can be very touchy.
If you run a regulator with a std 125 lb spring it gets very touchy when you're doing adjustments for +/- 1-2 psi.
I'm adding pressure to the top of the wastegate diaphragm like the pictures above show.
Brad
I got the hallman rx remote kit on a black friday sale. Cant wait to try it out this year.
