26 psi on stock bottom end?
Also both the "big bang" articles i read the engines were Making north of 500 crank hp NA. Dont see that much on the typical stock builds here. I'd be amazed if my JY 5.3 made 300 at the crank NA.
With an S475 I ran 25lbs on an OEM bottom end gen3 (weak rods like the ls1) motor. It was low compression (8.6:1) with 317 heads and dished piston 5.3 on E85. Timing chain eventually failed, but I don't think the rods were in any danger on my setup.
840ish whp going by 1/8th mile weight/trap.
786ish WHP going by 1/4 weight/trap.
