Behind the wheel difference between superchargers and turbos?
Both of the procharged cars have about 500tq at 3500rpm and mine does too. The difference in "feeling" is that i get close to my peak torque much sooner and carry it throughout my powerband. You can see the area in the graph where people say its like the car got kicked in the *** and its that region where the car hits full boost. I ran a 26" M/T's on a 16" rim all last year and had very minor traction issues. I mean seriously, how much time do you spend below 3500rpm if you are ripping on the car?
The two powerbands are very different but as you can see if you compare the two graphs, the turbo graph has a lot more power under the curve. The tune matters a lot more in a turbo car because you can get very close to no lag. Both cars will be fast but there is nothing like the wildness of a turbo car.
I see a lot of responses from people using Pro-Chargers but what about a roots blower? I love the way roots blown vehicles drive. The throttle response and torque are so fun. I've never driven a modern turbo car besides a diesel. The car is purely a street car and my goals are modest power wise. I'm actually more interested in enjoying the drive and making the power where I want it. Because of my setup, which ever route I choose will require a lot of fabricating.
I'm trying to decide if I should attempt to build a turbo motor, single or twin, that drives like a roots blown car would. Is it possible? Lets say low boost, 6-8 psi, and a 2000-6000 rpm power band. I've got a lot of research to do and a lot to learn so should I even consider a turbo setup? I figure it will be easier to fabricate the piping and exhaust manifolds than to fabricate a intercooled intake manifold. Unless it's all for naught of course. In which case, I would rather focus my attention on adapting the roots blower.
Thanks
Thanks
However with modest goals, yes you probably could achieve it with a pair of small turbos. It wouldnt be exactly the same, but it'd be pretty damn close, and you'd have easy access to effective chargecooling, unlike with a valley mounted blower.
But with such modest goals....a 454 n/a probably wouldnt feel so bad either.
Thanks guys. I appreciate and welcome the feedback.
Using a pair of small turbos, you'll be able to get a decent increase in power, with boost very early in the rpm range without any difficulty at all.
AGP offer these for their basic TT kit for the modern Camaro's http://www.agpturbo.com/borg-warner-...-turbocharger/
They're pretty tiny, not expensive and should spool very fast on most motors.
http://www.camaro5.com/forums/showthread.php?t=288657
http://www.camaro5.com/forums/showthread.php?t=304406
They wouldnt be cheap in alloy form, but they have been done.
http://www.erlperformance.com/erl-500-ci-turnkey
https://ls1tech.com/forums/generatio...00-ci-lsx.html
Obviously you wouldnt even contemplate boost with any of those motors though
If you want a centri type torque curve to keep tires on the street with a turbo it isn't that difficult
Heck I have been 60-130 in 4.7 on a 17" 255 mickey mouse Walmart hankook tire with a 420 treadware on a plain asphalt highway..... no fancy traction control or anything. Just a simple two stage time based boost control strategy
Sure, you can get a turbo setup to mimic it, but it's not going to be a simple, cheap setup. I have exactly what you want, and do with my car exactly what you're looking to do. Have a really fun car that drives awesome from 2500-5000rpm with plenty of usable power that doesn't shock the drivetrain or destroy tires.
No one will argue the under the curve power compared to a centri but having driven turbo and centri v8's a straight line is where most turbo's shine. In a corner I'll take my belt driven boost.
Really good traction control changes things.
The thread was resurrected by Snow Dog, so the last few responses are directed towards him.
In that respect, his desire for some torque and power between 2-6k on an LT1...really, a centri has no place in that request.
Yes one will make power, yes it will feel superb in the mid-upper rpm's. But at 2k ? Probably not that exciting.
Will a Rootes style offer performance in that range ? Absolutely, assuming total goals arent overly high.
Can a turbo setup be built to perform in that range ? Absolutely.
As for comments about a turbo building boost mid-corner. If you put your foot down with a centri/rootes it can potentially build boost faster than a turbo setup mid corner. So are those concerns valid ?
Not really. If it was a high powered, high boost turbo setup, then perhaps yes there are concerns. Nothing that cant easily be dealt with though, with some sort of intelligent control over boost with a turbo setup.
But the same could apply to a high boost high powered centri setup.
There are many ways to achieve the goals, all have good points and not so good. But all can be configured to perform one way or another.
The harder part comes when low traction scenarios are involved, or when seeking lots of power. But for mild setups, almost any will be great.
All great points.
With the electronic boost controllers you can set up a turbo car to do exactly what you want it to. Boost by gear, boost by rpm, ramp rates etc there is just about nothing that you can't do with a turbo car.
[/URL]
